Discuss Sticking Pvc to tanking in the Tanking and Wetrooms area at TilersForums.com.
88
Wales
Hi I have tanked my shower with mapei waterproofing,now I need to stick pvc panels to the ceiling.can anyone recommend something I can use please.
Are there no fixing instructions with the panels . I work with a guy who sometimes puts pva panels and he battens the ceiling and uses hidden nail technique . Have you tanked the ceiling ? If not it doesn't gave any relevance to the question if you have and you intend sticking panels then as above .
J Sid
I'd imagine if you can get something that bonds to the pvc it would be ok on the mapei.
Waluigi
It’s an educated guess based on knowing what it will stick to in the industry after reading the data sheet before using it on waterproofing jobs, in particular when it’s been used to bond Kerdi sheet to ‘difficult’ substrates. However I’d not actually use Kerdi Fix, I’d find something else that has similar characteristics yet less expensive due to the volume of Kerdi fix required.
In reality I’d not be bonding PVC to a ceiling full stop, I’d mechanically fix them.
J Sid
if you are going to advise using a product which you don't know will work it would be a good idea to say so @Waluigi .
we wouldn't want someone to take advice which turned out not to work would we :eek:
we don't know what education you have had so we know how educated your guess is :(
Reply to Sticking Pvc to tanking in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
