Discuss Sticking Pvc to tanking in the Tanking and Wetrooms area at TilersForums.com.
Waluigi
Been on to mapei they said speak to pvc supplier.speak to pvc supplier and they said speak to mapei lol.
I know you’re not keen on mechanically fixing the PVC but how about using a small amount of neutral curing silicone at each fixing point as it meets the membrane?
Is there a reason you’ve tanked the ceiling? My apologies if you’ve already explained.
Time's Ran Out
Well there you go - a little bit more information - a steam room!
Gone from a simple shower to specialist installation in 1 sentence.
Wall construction, insulation, moisture breaks, temperature ranges....
88
Wales
All I want too do is stick this on the ceiling that's it. Will only be 1200mm pieces.
Waluigi
Sticks like sh** would be fine
that a guess @Plan Tec Tiling ? Or have you spoken to @Mapei UK Marketing or ‘sticks like S**t’ about using that product for this application?
if you are going to advise using a product which you don't know will work it would be a good idea to say so @Plan Tec Tiling.
we wouldn't want someone to take advice which turned out not to work would we
*when I say ‘we’ I’m speaking on behalf of lots of other people too ;)
W out:praying:
Boggs
1,118
Uk
CT1 or Sticks Like S**t.
Lesson learnt by me from @Plan Tec Tiling . Test . Get some spare plaster board , tank it , stick some pvc on using different adhesives and see if any fail or work . Then you are good to go . Also please post results .
Q
Qwerty
@Waluigi , you've been told before about personal attacks of members including staff. A simple 'disagree' would suffice, I know you know where the button is!
And yes, I've even stuck Bushboard to Mapei tanked walls and skeilings with sticks like sh** and it works! So my advice is sound. Is it what @Mapei UK Marketing would recommend, probably not. Does it work, yes. Have I done it myself, yes.
Shame I didnt receive this a few hours ago as I spent most of the day with Nick & Alan from Mapei and we had similar conversations on other applications throughout the day.
Reply to Sticking Pvc to tanking in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
