Just Rizzle
mines by sovereign but any decent one should do the job
Discuss Limestone Discolouration in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
have got Ultra coming to site this week, and am meeting the builder again to run through the floor construction for possible faults there, but testing the tile on a dry screed with same adhesive will be a good indication.Have you done a test on the stone on a substrate you know to be dry with the same adhesive? Surely this will show whether it's adhesive bleed or a screed issue.
if ditra was to be used as a waterproof layer, what happens to the trapped moisture in the screed?
The interconnected air channels between the cavities on the underside of the Schlüter®-DITRA 25 matting remain open. This allows moisture in the substrate to evaporate, therefore neutralising vapour pressure.
Why do people not decorate the new plaster before the tiles are fixed ?
Reply to Limestone Discolouration in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
