Myths and Misunderstandings: Testing the water resistance of grout
Even with easypoxy they're saying it's essential.
Going to do one now that is ceramic, thin grout join, large tiles, plasterboard, epoxy grout, shower but NOT power shower. See if it lets me unselcted it then.
Intermittent wetting (not frequent - and not power shower)
STILL WITH TANKING AND WONT LET ME NOT SELECT IT!!!!!
So basically, unless it's dry, or a kitchen wall, you need tanking if you're buying BAL.
This wasn't a choice. They say you NEED it.
BAL M40 Tiling Specification (Contractors)
Specification Title: Shower
110
TILING TO BATHROOM 2
Tiles: Glazed (Porous Body) - Jones Bathroom 3
Size: 450mm x 450mm x 9mm
Base/Background: Plasterboard
Preparation: General preparation as clause 300
Apply BAL WP1 Tanking as clause 520
PRIMING: BAL Prime - APD (Apply priming coat of BAL-PRIME APD as clause 462)
TANKING: BAL-WP1 TANKING SYSTEM (Apply BAL-WP1 TANKING SYSTEM as clause 520)
Bedding: BAL-THIN BED SOLID BED TROWEL (WALLS) as clause 740
Adhesive: BAL WHITE STAR PLUS
Grout: BAL MICROFLEX GROUT (NARROW JOINT)
Colour: White
Joint width: 2mm
The things you'll do to prove a guy wrong lol
How is tanking a health and safety issue? PMSL
when you are wrong you are wrong and you are wrong on this one but you keep on insisting you are right. its me LMFAO at your advice to the poor sod in the other thread stop confusing her with bullsh*t and try helping her FFS
I just called the BAL rep and had a chat about this and funnily enough he doesn't agree with dans technical advice ether. He found the idea that water behind the tiles is a normal occurrence ridiculous and his first thought was this would be a health and safety issue.
Which BAL rep was it? I think he needs to go on a course. Or read the back of a bag of grout.
I assume you've seen my powerspec specifications above that prove you and the BAL rep wrong then? lol
How is tanking a health and safety issue Deano?
What's the reps name you spoke to? I assume it's the same rep covering Staffs.
kieran i will pm you his number
I'm sure he wouldn't mind his number in the tilersforums arms. He's not going to get anybody but potential customers ringing him.
If I select vitrified tiles, for a floor, with 3mm joint, on concrete, I'll give it to you, it doesn't insist on tanking.
Specification Title: Tiling a Shower
110
TILING TO BATHROOM 4
Tiles: Vitrified - Vitrified Tile
Base/Background: Concrete
Bedding: BAL-LARGE FORMAT TROWEL (FLOOR) as clause 820
Adhesive: BAL SINGLE PART FLEXIBLE (GREY)
Grout: BAL WIDE JOINT GROUT
Colour: Charcoal
Joint width: 3mm
Kieran 07792470430 who says it's a health and safety risk to use tanking in a shower with BAL products. Allegedly. 🙄😵
I've had enough of this thread lol
I wont be replying any more. It's the pettiest thing I've done and seen done since I was about 12.
I'm just not ready to fall out with a human over tiles, I need more time before I do that pmsl it seems I'm just not that way inclined. 🙂
All the best to Deano and those who wish to use or not use tanking in showers. lol
yes is prop best you just stop now lol
if there is water sat behind the tiles it is not normal and you have a problem and that is all i have been saying from the start.
The D,
andytyler,
The D,
andytyler,
