advise required...
Hi Guys
Right - here's the pictures of my first attempt - I haven't grouted yet but on your advice I've stuck to the BAL stuff - got the White star and the BAL grout.
broken link removed
:hurray:
nice straight lines cappsie, how will yo finish around the diamond window, L shaped trim ?......Gaz
hmm trim... nope.
I didn't put any trim on - I'm now thinking that was a bit of an unplanned oversight 🙂
Guess I'll have to mega grout that bit 😉
Srtaight lines were a pain tho 🙂
Well done Cappsie, nice job so far. I must say your walls don't seem to run out very much, you are a touch fortunate as you appear to have full tiles into the corners. That could have caused you problems if the walls weren't straight.
It is normal to try and have a cut into the corners so you can follow the line of the wall closely to get a nice finish.
I'm not being critical here you are doing a good job, just trying to give pointers.:thumbsup:
Grumpy
Thanks - very kind of you to say 🙂
I only broke about two tiles and that was doing the silly diamond window angles with a tile saw - mainly rushing through it to get to the pub 🙂
hmm trim... nope.
you can get a chrome matwell 90 angle trim...will plant on around the window after grouting ...this will look planned....Gaz
advise required...
cappsie,
cappsie,
cappsie,
cappsie,
