Angle grinder wheels
That's not a surprise to be honest, the turbo blade is more designed for natural stone, concrete and ceramics wall tiles. The continuous rim is designed for similar materials or wet use in a bench type saw for some of the more dense man made materials.
Next job you have which is not porcelain give them a run.
We have some blades specifically designed for porcelain in the pipeline and I'll send you one as soon as we have them here.
Is a turbo blade not really suitable for Porcelain Alan? Always bought them as they were dearer so I assumed better on porcelain, but interestingly the Monty DNA isn't 'turbo'. Have an Addax blade on at the minute, and a Tryolit porcelain blade before that. Neither are anything special so will go for the Pro Gres next time I think.
It's not quite as simple as the design of the diamond segment alone.
The diamond content and make up of the metal in the segment itself determine what product the blade is best used on as well as the shape of the segment and the size and shape of the gaps in between etc.
A turbo design is a cross between continuous and segmented and has tended to provide a faster cut (hence it's name), in porcelain though the best finish still seems to be obtained with the hot press, laser cut, continuous rims blades like the blue one I included an image of earlier in this thread.
Fundamentally the material you cut and the finish required still determines the best design of blade for each requirement. It's very difficult indeed to produce an all round blade that will cover most products.
Things like laser welded segments have become selling points, the major upside of laser welding is it's far less likely to throw a segment off if a problem occurs or the blade becomes trapped or you hit an unexpected lump of metal etc. These are far more important in concrete blades than most other types, although we do laser weld our professional granite cutting blades.
the latest blades have a high nickel content in the diamond carrying paste around the blade nickel is more brittle than the conventional brass based pastes conventional diamomond blades are made from which dull over time and need running through a sandstone to liven the diamonds back ,the nickel being brittle microscopically cracks exposing the diamonds ,I was told this by a diamond blade manufacturer , most of the industrial diamond is manufactured in Ireland ,I bought some blades off the guy and have to say they have been really good and were very cheap
Beava diamond thin turbo blade. £12.99 with free postage. Very good blade at a quarter of the price
Where can order this blade?
Eduardo.how do you know this is a good blade at such a cheap rate if you are asking where to buy it!!
Arewe lost in translation !!,
i do understand this problem
I think Eduardos post got mixed in with the post he quoted Jonny, the original is above.
I use this in the past,for one company based in Leeds,is really good blade,but this company tell me to pay for this 35 pounds.I try to find,but the price is 21 pounds,so if someone sell with 13 pounds,I want buy this,Thanks.
i just ordered 4 of the beaver blades from ebay 115mm and 10 black diamond 125mm porcelain blades, unbelievable price £30 for 10 blades, the beaver blades were £46 for the 4
Gazzer,
Dan,
Gazzer,
Dan,
