Discuss Anhydrite or Concrete - dont know in the Canada Tile Advice area at TilersForums.com.
Filip
498
Midlands
looks like a screed layence has settled on surface like anhydrite i would sand off as this is loose and will not secure the adhesive or slr and must be removed before tiling
From what I have learnt over the past 48 hours that is also my thinking, its like some areas were wetter than others and its just pools of cement dust gone hard in those areas, if it comes off then I will take it off. Am I ok with the primer I plan to use, reason being its what the local supplier stocks
Ajax123
1,213
Lincolnshire
If its barratts outside London and its a house it is probably self compacting concrete. Not only would it have laitance it will also have a curing agent on it. As with all screeds and concretes it should be mechanically abraded prior to bonding floor coverings.
Tile Shop
Just looked myself and yes it does doesn't it, I am getting my daughter to send me a picture of the end of the box with the info on but while she is sending that - here are a couple of shots from the brochure
View attachment 96590 View attachment 96591
For anyone who cares or was unaware or for future reference, the term "ceramic" can be confusing. We commonly know it as a glazed clay tile, but its also a description used in the industry as an umbrella term for any clay product that goes through a firing or kilning process, which also includes porcelain (glazed, double loaded, twin charged and full bodied), quarry tiles and several forms of terracotta.
As you were :)
Filip
498
Midlands
I dont actually know what the difference is in terms of working with and I am still unsure why a previous poster said they were not suitable for the floor. And why choose a porcelain tile over a "normal one" as also am I right to think I will be needing a 8mm wheel for my Bellota cutter as it only came with a 6mmm and I have tiled a bathroom - floor to ceiling with that little fella
EDIT - just seen the
Tile water absorbtion experiment
so water proof is 1 reason to use porcelain over ceramic
Filip
498
Midlands
Just received the box info dont know what that tells us but the tile defiantly says porcelain on the bottom
Reply to Anhydrite or Concrete - dont know in the Canada Tile Advice area at TilersForums.com
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
Help! New DIYer here - I’m preparing my bathroom floor to lay ceramic tile. Removed the vinyl...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
Midlands
    Votes: 6 4.7%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.7%
    Votes: 16 12.4%
    Votes: 31 24.0%
    Votes: 3 2.3%
    Votes: 2 1.6%
    Votes: 19 14.7%
    Votes: 18 14.0%
    Votes: 15 11.6%
    Votes: 6 4.7%
    Votes: 3 2.3%
    Votes: 2 1.6%
