Discuss Anhydrite or Concrete - dont know in the Canada Tile Advice area at TilersForums.com.
Filip
498
Midlands
Thought I would have an easy job to tile my daughters new build house kitchen floor but then I start reading on help forums about Anhydrite floors. But I do not know if she has one or not, its a new build Barrett home.
My local supplier stocks Tilemaster and I see that they do Anhyfix but the spec says it is not suitable for a normal concrete floor which I do not know if she has.
So what to do - do I sand and then SBR or APD and then use a normal cement based adhesive.
Tile Shop
I have a feeling that all Barratt homes are Sand/Cement screed, (based on recent local plots) but would double check with them just in case . Failing that, if you can take a picture and post it up here, we may be able to ID it for you. It wouldn't be wise for us to advise a solution until you know what you're dealing with.
Andy Allen
1,318
Gloucester
If its a new build on a housing site i can almost guarantee its a sand and cement floor, give it a good scrape to remove any debris, prime with an acrylic Primer and tile away..
BTW. .....They sometimes level the floors with SLC which can look like a anhydrite screed .
Filip
498
Midlands
Thanks chaps for the quick reply,pictures attached I will get my daughter to ask the site people as it is a big build that will be going of for years. I will have a look and a poke but I have a picture taken when they let us in at pre plaster stage to see where all the pipe and cables were and it looks a bit light grey like the photos of Anhydrite I have seen. But another one taken the other day when they had to rip out and replace a cupboard looks like sand and cement.
Filip
498
Midlands
been over today and spoke to a site manager who said that the floor is concrete and then its floated to give a smooth surface. On closer inspection I can see that some of the top smoothed layer has come off leaving a harder screed looking surface.Some areas are compleatly free of any top surface. Some of the smoothed areas are quite hard and others are easily scrapped off. Is there anything wrong with this approach.
Sand off the areas that are weak and leave the rest.
Seal with two coats of Prime Plus | Flexible Primer & Bonding Agent | Tilemaster Adhesives - http://www.tilemasteradhesives.co.uk/preparation-products/primeplus-flexible-primer-and-bonding-agent
And then use Standard Set Extrabond | Standard Setting, Polymer Modified, Wall and Floor Tile Adhesive - http://www.tilemasteradhesives.co.uk/adhesives/standard-set-extrabond-tile-adhesive
Its a kitchen and the tiles are ceramic 60x30.
Attached close up pictures of floor
Time's Ran Out
Check the stock before you start!
I had the same situation last year with this range.
Topps advertise that they are made in Britain and are suitable for floors - both facts are not true. The tile they show is a white biscuit wall tile that they are selling like BCT tiles with soft glaze, totally unsuitable for floors. However the tiles I received boxed as above were in fact porcelain and made in Turkey!
When this was pointed out to Topps in M25 corridor area of Redhill they stated that they were changing supplier of this range and hadn’t updated their webpage!
So they are advertising a British range of ceramic tiles to look like British quarried stone, but switching the supply to a Turkish porcelain without telling you! Sums them up really.
Filip
498
Midlands
Reply to Anhydrite or Concrete - dont know in the Canada Tile Advice area at TilersForums.com
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
Help! New DIYer here - I’m preparing my bathroom floor to lay ceramic tile. Removed the vinyl...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
Midlands
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 2 1.2%
    Votes: 5 3.1%
