Discuss Best Deal Supplier's in the Australia Tiling Forum area at TilersForums.com.
I've been using the Genisis system for a good while now, it can cope with material of up to 70mm in depth, like the breaking capabilities of your tile cutter you'll soon get to know where it is with them also. If your doing a job with stone etc you can get a battery plier that will remove the strap with no movement, hence no scraping or alternatively you can simply pull it off like you would opening a bottle of beer ;)
In all seriousness I can't fault it as a system, it also is worth getting the large format tops for anything over 600x600 or heavy stone
I priced this up from protilers and as far as I could tell it's similar in cost to Raimondi, well it was until the bases in Italy were found.
Just this min got txt from DPD
My delivery from Italy, will be here today.
I placed an order at 13.26 Fri afternoon!
Seems good enough to me!
Very pleased with service, I've been trying to place an order in Ireland on a website since Friday, and I still have managed to complete it, technical stuff,
Web page won't complete order.
And they want 3-5 working days to deliver a very very tiny 20ml bottle of fluid I need for a job! Hahaha
You sure about your statement Lee? Hahahaha
L
LM
I'd be better using pigeons by the sounds of that lol
I
Italy
To be honest that's ridiculous, to make the system viable they shouldn't be charging anymore than £12 per 200 or you'll simply go to an alternative system. Am iright in thinking the Ramondi system works out at about 6-7p per strap?
I've never used the Ramondi system as I've said before, but I would trust what the likes of Antonio and Marc etc go with and if J had to pay what you've been asked Id simply change, that said the Genisis system is still a good one, your just being ripped off!
call me? ready, ready one speaking? no compry :(
I
Italy
marc strength, try similar raimondi from Rome !!!
I am curious if to say julian, equal rls !!!!
J Sid
these too seem RAIMONDI
but not RAIMONDI
and not go well
now await more tests before buying.
julian say same Raimondi
now we await marc ;)
I have done a couple of jobs now with them and had no problems even when I mixed them together with some Raimondi ones I had left over .
What went wronged with your ones Antonio?
I
Italy
I could not get leveling.
when forcing pliers, they bend left and right, and open
slot.
too soft.
no rigid
Reply to Best Deal Supplier's in the Australia Tiling Forum area at TilersForums.com
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
Hi guys, Last time I posted here I was having a first attempt at tiling the walls in a shower...
Waluigi
I'm a chippy, I fit a lot of kitchens and some bathrooms, inevitably I have done quite a bit of...
20K
I'm going to be using the ultra rapid set S1 white adhesive now being sold at CTD. can't find a...
Flintstone
F
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
