Best Tile Adhesive for Walls and Floors? Voting is now CLOSED - Results are in!! Well done MAPEI!
Got told back in the summer PCI are pulling out of the uk market.
Sent from my iPhone using Tapatalk
BAL slightly ahead so far. Then Mapei, then Weber. Still plenty of time for others to catch up perhaps. Though I think it'll be one of the main three that lead this year.
Bal and weber for me. Can someone add my vote please as I'm on tapatalk. PCI are definitely going, as I am led to believe BASF are pulling the plug on it.
BAL or Weber then mate? Which one did you use the most?
What will you use instead then now mate? Got any options?
The pci carrament isa special adhesive for sensitive white stones .there are other similar products I can use but I actually liked Shane the pci rep and he did me great pallet deal .the pecilastic is going to be more of a problem to replace if no one is going to bring this in.
I use it for some developers instead of ditra as it cuts costs down and also use a lot when a tile bridges over two substrates . I use bal fast flex rubber adhesive on top of pecilastic and this is as good as I can rethink of but no guarantee and the pecilastic is only 1mm thick.
for main adhesive I use tile master as posted earlier and for what I do this is far the best value for money . I think that as word spreads tile master will becomes much bigger player if they want to.
Gazzer,
Gazzer,
