cornish_crofter
I'm soon to be laying tiles on a cement screed floor. I've done these before without problems.
However there are some CH pipes that are buried in the floor. These are quite close to the surface. When the old lino was down you could feel the heat via the floor!
I'm concerned about adhesive failure as a result of the heat. Should I be and if so, what precautions should be taken.
The floor is too small for a decoupling membrane under normal circumstances. The area is around 6 ft by 6ft.
The tiles haven't been chosen yet, but I suspect the client will go for 300x300 or larger for the floor.
