Discuss Dewalt D24000 in the Canada Tile Advice area at TilersForums.com.
Hi all,
Well the D24000 saga continues. Have been having real issues with setting up the Dewalt 24000, at only a few weeks old and after being used on only 2 jobs have been troubled with the saw running off line. After hours of adjustments I have just about got the saw cutting true in a straight line. However when I tilt to cut 45 degree mitre on a straight edge of tile guess what...the mitre cut is now running off line :mad2:
Has anyone come across this issue with the D24000? Its driving me nuts.
Cheers
Dave
Chalker
1,058
Tadcaster
Strange, I have tried everything and it seems that just when I have it cutting on line as soon as I flip to mitre it runs off again leaving top of tile cut correctly but by the time the cuts finished the other end still has 2-3mm of material left.
Could it be me???....hope not.
probably just the wheel. Try putting a bit of side pressure on with your finger
Found this in a previous post by Peckers and may explain my issue re mitres.
dewalt blade
90 degree cuts
very good fine clean crisp cuts and cuts very fast too on 90 degree angle and takes slithers off with out a problem.
45 degree cuts
if you are doing mitres and you cut your tile with a square edge then turn it on its back and do the mitre this way leaving about a 1mm edge on the front edge of the tile then i did find that the cut tendded to wonder a bit at the end off the run leaving it about a mm wider at the end.
Montolit dna blade=
90 degree cuts
very good clean crisp cut once again, but it diddnt seem as quick as the dewalt blade to do the same length off cut and needed a bit more effort to push the tile threw to get the same speed. It also removes thin slithers just as the dewalt blade does.
45 degree cuts
if you are doing mitres as above it is better as it doesent wonder towards the end of the cut leaving it a perfect 1mm all the way down the line.
Reply to Dewalt D24000 in the Canada Tile Advice area at TilersForums.com
So, I bought my first home with my wife after saving for about 10 years and have been thrown...
8K
Hi everyone, I really need some pro advice as I have just had a bathroom fitted and the tiling...
Deleted member 53945
Anybody know where I can get a box trim 15mm wide in chrome or aluminum? Have scoured the...
Kieks
K
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
Hi all Hoping for some opinions on how to handle an ongoing issue in having with my tiler He...
2 3 4
15K
Scotland
Dewalt D24000
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
