diamond blades, again
Thank you both.
PREMTOOL Turbo Fastline 115mm x 22.2mm Diamond Blade TUR115 - https://www.protilertools.co.uk/product/premtool-turbo-fastline-115mm-x-22-2mm-diamond-blade-tur115
I’ve just used this bade on a 70 metre extremely hard porcelain floor I’ve just completed, all dry cut and no chips whatsoever......probably the best blade I’ve used in years and cheap too
I still have the page open on my desktop. Found it looking through earlier posts yesterday.
I found the old Bosch blade order on Amazon. Two 125mm blades, one construction and one tile for £17. Maybe I should try that one too. Worked before.
This is the only piece not already placed, and it is the offcut. It was probably one of the first cuts so the blade was not bedded in.
I'm afraid I am used to using a stationary wet saw.
Montolit are one of the best I’ve used. Montolit CGX
I still use the Chinese blades though. They work really well and are a fraction of the cost of Montolit.
I’ve had the same Montolit blade in one grinder for 8 months. I really rate the blade.
Paul Giovanni Raimondi,
