Discuss discoloured satin tiles in the British & UK Tiling Forum area at TilersForums.com.
N
Neil Booth
Hi I've just retiled our existing shower cubicle with British Ceramic Tiles "Satin White" tiles. The guy advised Mapei products so I've used Keraquick and Ultracolour white grout, all onto Hardibacker board primed with Primer G.
After just six weeks or so the tiles appear to be turning grey in patches at their edges ruining the appearance. This is presumably due to water getting under the grout despite my being extra careful to ensure I did it properly.
Admittedly the new shower is pretty powerful (Mira Excel) but even so I wouldn't expect this sort of problem.
Where have I gone wrong?
DHTiling
It is as Jay has mentioned....it's water getting into the tile bisuit, it will dry out but as you use the shower regulary then it will always be like that...
Are the joints full to tile face..? if so then a grout sealer might help to repell the water...it's nothing yo u have done, it's a common fault with some tiles as the glaze does not cover the edges properly.
jay
hi neil it might help not an easy job id be more inclined to let it dry out and seal with a waterproof sealer iv used a grout sealer called sure seal you can get it in a spray can spray the grout and its sealed try a bit on paper towl and run it under water it beads on sprayed section not sure if its aval over there but it might be worth a shot hope this helps :8:
Reply to discoloured satin tiles in the British & UK Tiling Forum area at TilersForums.com
Hi chaps, I’m mid way through my first DIY tiling, taking 3 half tiled walls above a bath to...
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
Hi, Looking for advice please. 2 problems! We have just had encaustic tiles laid in our...
7K
Qwerty
Q
So after a couple of weeks trialing @ISOMAT UK products, thought it was time to give initial...
9K
We had a wet room installed about 8 months ago. The floor is tiled with large 60x60cm porcelain...
116K
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
