White Room
Had to repair a shower where the tiles had been dot and dabbed with tub stuff, About 12mm thick:huh2:
Paisley, Dot and Dab, Dunlop. Could be one for you James.I recently finished tiling a bathrrom, brick effect ceramic tiles, had to use dot n dab to get flat results. I used dunlop set fast plus dotting 4cubic cm 2 inch apart, this would ensure good adherence but skim the backs of the tile to help resist water penetration, you could also skim the walls all the same. I will grout with brilliant white fix-n-grout and pack in well to give support to the corners of each tile.
I rarely use dot n dab, its not good to use this technique with pre-mixed adhesives as its designed to stay wet and fresh at greater thicknesses. In fact avoid pre-mixed adhesive altogether I say, and keep that for kitchens as many ppl nowaday have showers on their baths. I know not to dot-n-dab floors.
Make up your own minds about what technique suits you as a tiler, albeit it depends on the job, but bring with that a better sense of professionalism when doing so.
Could someone please tell what are the problems and pitfalls of spot fixing.
