The 3 porblems with d&d are.
1. The risk of exceeding the bedding depths. 6/5mm, 10mm in isolated areas. this can result in the adhesive exsesivly shriking. As I said I looked at a failure yesterday of 800x800 tiles on a wall, where the thick bed of d&d adhesive had shrunk, and caused the tiles to debond.
2. You need to make sure you're getting 100% (or there abouts) coverage in wet areas, and 80% elsewhere. This is to be able to support the weight of the tiles.
3. The BS says weight limits of 20kg psqm on plaster, if you have a 12mm stone fixed to 5 or 6 dabs of adhesive, then you are far exceeding your weight limits.
If you can d&d, and overcome those REAL issues, then good luck to you. I'd rather see the walls made good, and serrate away.
This isn't from an adhesive rep. Its from a tiler of 10 years, who as always seeked to improve his knowledge, even if it means eating a few large slices of humble pie. Which i have done, and continue to do.
