Discuss Dot & Dab travertine? in the UK Tiling Forum area at TilersForums.com.
Sibs, to say notch trowelling will give something near full coverage sounds very ignorant - you must tile over perfect walls. :mickey:
i wonder how you would fix these sucker mateHi
All the guys a spot on, dot and dab fixing was outlawed by BS donkeys years ago.
Incidentally, the term waterproof in relation to tile adhesives is generally missused,
any adhesive manufacturer using the term waterproof in describing a ready mix or cement based adhesive is missleading the tiling public and in my view should receive a good slap. The correct term is water resistant i.e. unaffected by water.
Keith W
british standards are guide lines not laws they are updated from time to time as new fixing methods come along if you follow the guide lines good luck to you but if you dont the tile police wont come and arrest you lolHi
Keith W
But if a tile falls off and does some damage, you will be liable.british standards are guide lines not laws they are updated from time to time as new fixing methods come along if you follow the guide lines good luck to you but if you dont the tile police wont come and arrest you lol
If all you can do is spot fix them, then I'd say they need to be mechanically fixed.i wonder how you would fix these sucker mate
1000 x 500 x 20 weight 80 kg Indian granite
spot fixed ?? (theres really no other way )
i couldnt agree more this can be achieved if done correctlyI've worked for BAL only 4 months now, and I've seen plenty of reasons why spot fixing , and not getting a full bed of adhesive doesn't work, especially on floors.
If you have to guage your adhesive inatead of notching, you need to be getting 100% in wet areas.
never done this sort of work mate have you ??If all you can do is spot fix them, then I'd say they need to be mechanically fixed.
If you're just adding spots of adhesives to the back of a tile that size and weight, you're asking for trouble.
Reply to Dot & Dab travertine? in the UK Tiling Forum area at TilersForums.com
