Discuss Dot & Dab travertine? in the British & UK Tiling Forum area at TilersForums.com.
oogabooga
Sibs, to say notch trowelling will give something near full coverage sounds very ignorant - you must tile over perfect walls. If you've ever had to remove tiles installed in that manner you'd see for yourself that coverage is nowhere near what you might hope. If you want to parrot what you've been told then that's fine - just understand that it is the coverage that is important, the method used to achieve it is of secondary importance.
As for the lack of membrane, if you want to believe that notch trowelling will afford some protection to the substrate, well good luck with that!. Just so you are clear - I am not defending this guys work, it looks dodgey to me, it's just that you're rubbishing a method that you know nothing about and that clearly works everywhere else in the world except the UK:mickey:
U
uug197h
just to throw a spanner in to the works, just been to a job to remove a radiator and chance it to a towel rail the tiler had cut round the brackets so i had to remove the tiles and replace them, the tiler had notch troweled them but i pulled them of with my fingers. the tiles have been up over a year. the customer is looking at getting the full bathroom redone now, so even using a notch trowel dosen't mean the job is done correctly
sibs
And sweden!
oogabooga I wasn't rubbishing anything I was asking a question and when I tile walls I make sure I get 100% coverage and no none of the walls I have ever tiled have been completely flat and in such situations I would be back buttering my tiles as well as troweling the walls and also I think it depends on the size and type of notched trowel you use as to weather there is enough adhesive on the tile to fill in the valleys when it is pressed onto the walls...I tend to make sure there is if I do do that.
Don't forget I was refering to the walls in spankys bathroom. Newly hung plasterboard should be pretty flat don't you think?
On the subject of tanking the point I was trying to make is that spankeys walls weren't tanked and dotting and dabbing adhesive onto tiles in a shower area with untanked walls will afford the walls less protection against water ingress than if they were fully covered with adhesive. If you read my post you will see that I did say untanked walls weren't the ideal and I was refering to the fact that spanky's walls weren't, not that I wouldn't! If the customer offered me the use of aqua board or some other tanking system I would have used it but the contractor and the tiler turned it down.
At the end of the day all you can do is recommend that the area is tanked and if they don't want to spend the money on it then thats it but this guy did and the tiler didn't want to use it.
You still haven't answered my question!
K
Keith W
Hi
All the guys a spot on, dot and dab fixing was outlawed by BS donkeys years ago.
Incidentally, the term waterproof in relation to tile adhesives is generally missused,
any adhesive manufacturer using the term waterproof in describing a ready mix or cement based adhesive is missleading the tiling public and in my view should receive a good slap. The correct term is water resistant i.e. unaffected by water.
Keith W
pjtiler
Hi
Keith W
i wonder how you would fix these sucker mate
1000 x 500 x 20 wieght 80 kg indian granite
spot fixed ?? (theres really no other way )
Spud
Hi
Keith W
british standards are guide lines not laws they are updated from time to time as new fixing methods come along if you follow the guide lines good luck to you but if you dont the tile police wont come and arrest you lol
Branty
But if a tile falls off and does some damage, you will be liable.
Branty
1000 x 500 x 20 weight 80 kg Indian granite
If all you can do is spot fix them, then I'd say they need to be mechanically fixed.
If you're just adding spots of adhesives to the back of a tile that size and weight, you're asking for trouble.
Spud
I've worked for BAL only 4 months now, and I've seen plenty of reasons why spot fixing , and not getting a full bed of adhesive doesn't work, especially on floors.
If you have to guage your adhesive inatead of notching, you need to be getting 100% in wet areas.
i couldnt agree more this can be achieved if done correctly
Reply to Dot & Dab travertine? in the British & UK Tiling Forum area at TilersForums.com
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
    • Friendly
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
