gamma38
Do it right, or let someone else do it wrongSo if I had a job tiling a bathroom walls 18m2 on to plaster and my tiles was 22kg what would you suggest I do about it?
If it was a nice flat wall id probably use 2kg pm of adhesive thays y I have estimated 3/4 kg
Talk is cheap LOLDo it right, or let someone else do it wrong
Isn't it, do you get bored easily????????????Talk is cheap LOL
Talk is cheap LOL
I’m just intrigued what extra prep you would have me do on a job for the sake of 2kg but if you are just flapping your gums and giving it the big one then that’s ok there are quite a few on this forum at the moment that do not like having there posts queried.Isn't it, do you get bored easily????????????
Not what i was saying or meaning, your just picking what i wrote to the inth degree, at what weight limit would you deem it acceptable then, if 2 kilo's is ok why not push it to 4 kilo's or 10 kilo's, there is a limit for a reason. Sure i understand you can get away with things but if something ever went wrong you wouldn't have a leg to stand on. To answer your question though, depends on the given job, the situation etc, remove plaster and overboard, stud then board, remove plaster and dot and dab, there are loads of options. As i said most of my customers are more than happy to have the extra prep done, if they are not then i don't really want to be working for people like that.I’m just intrigued what extra prep you would have me do on a job for the sake of 2kg but if you are just flapping your gums and giving it the big one then that’s ok there are quite a few on this forum at the moment that do not like having there posts queried.
I totally agree Dave, but if you install a better substrate it's a win win all round i say. Plus you get the benefit of a bit of extra work, and a customer that recommends you on the basis of being thorough.If i can chip in without being chewed up ... standards are a suggested limit that is deemed to be safe... as a tiler you have to take each job at face value and decide if you are willing to go say that extra 2kg...
Now on another note .. PB these days is a capable of holding more weight than currently suggested in BS and B/gypsum will probs be upping that limit with some luck .
So before knocking back a job , think!!!!
ok just my 2 penneth, will shut up now ..
I totally agree Dave, but if you install a better substrate it's a win win all round i say. Plus you get the benefit of a bit of extra work, and a customer that recommends you on the basis of being thorough.![]()
I voted yes, but I will be going to the TTA confession on Sunday. I just hope I don't get Excommunicated.:yikes:
they wont even let me join.......
because when I enquired I refused to give them finacial details.....and that was that as they say!Why..?..
I see what your doing here :lol:, to be fair i wouldn't nowadays, as i said to deano i made my cut off point and i stick to it. Maybe sometimes to my detriment but most people round my way are more than happy to go with it once you explain your reasons. Plus if you prep it it usually ends up flat, not builder flatWhat if the customer will not budge... would you go 2kg over ... I would if i was ok with the substrate prep..
