Excel Spreadsheet
Ive tried but because it was a spreadsheet it wouldnt upload. I can email it to you to try? Hope its not being bigged up into something better than it is!
Yes it looks like because it is an .xls format, it wont upload. The system will accept PDF and pictures but that wouldn't allow the formulas to work or any data entry
Thanks Andrew, ok, as promisded I will send you a sheet I use for pricing and invoicing, its slightly tricky if never used so I will need to put some notes on it. It also uses macros so you may need to adjust the settings within excel for it to work properly, you will also need to change it to the materials and prices you get from your local suppliers as the sheet is Taylored for me.
Ahhhh okay.
That'll be for a security reason no doubt as it can be used as a database etc and the server doesn't like databases it doesn't own/manage.
It'll have to be emailed around the place then I'm afraid. 🙁
Excel Spreadsheet
Tags Tags
aus usa
Andrew Case,
Andrew Case,
