Guest viewing limit reached
Grout, grout and grout
Polymer modified cement based grouts are more flexible than epoxy. Or at least they are in Mapei's case.
Kerapoxy vs Ultracolour Plus as an example:
Flexural Strength (N/mm2): KP = 31, UCP = 9
Compressive Strength (N/mm2): KP = 55, UCP = 35
Hi Paul. Posted this on the TT forum hope you dont mind ? No name mentioned just the facts 🙂
It doesn't exactly. But a grout that can resist that much flexural pressure ain't gonna be that flexible is it. Its rigid, its higher density and solid as ****. Grout needs to have a lower denisity and capillaries in it to allow flex and limited movement. Epoxy doesn't have that.
Like i said, there isn't a test for actual flexibility defined by any standards, but the flexural strength is a good indicater.
Don't have to take my word for it. Ask Bal, ask Mapei, ask Ardex..... Or do your own test.
Rule of thumb i was taught and have stuck to for 20 years:
CG1 - not flexible
CG2 - flexible
Epoxy - flexible but nowhere near as flexible as CG2
None. I've cleaned the float after use. honest 😉
More like i've left it and forgot about it for a few weeks and "borrowed" a new one from stock.
Simon Dale,
Tile Shop,
Simon Dale,
Tile Shop,
