Discuss Help! SLC fail - Self levelling compound failed Pro 50 in the Australia Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
floor was down nearly 3 weeks before it was turned on.
I have checked the customers stat (intelligent), as far as i can tell it hasnt been above 27c.
it is either thermal or early drying shrinkage which you would have seen before you tiled. The dry lake bed though is absolute classic symptom of over heating too early in the process. Someone isn't saying something IMO.
AliGage
Subscribed
4,531
1,188
Peterborough, England
That looks like it's been cooked. Underfloor heating too soon or too hot. What you are describing is classic thermal shock. I suspect some one is not telling you the truth about the sequence of heating post tiling...
My thoughts exactly
Budha7
Spud
whoa. if thats the case, how the F. do I prove that?
On turn on the floor was 20c, I turned it on, as far as I am aware, i then programmed it to 24c for 3 days, then upped it to 27c. Which as far as i am aware is where it is stayed?
was it turned on prior to the thermastatic control being fitted ? it happens a lot some sparks wire it to a plug end for testing i had one try it on my job last week
Reply to Help! SLC fail - Self levelling compound failed Pro 50 in the Australia Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
I’m nearly there with a bathroom tiling Project and managed to make it this far before getting...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
23K
Deleted member 57709
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
