Hi, looking for some support with first travertine bathroom. Thank you
Beags
Hi everyone,
I'm a couple of weeks away from beginning my first tiling job in my bathroom. I've been searching this site for several days now and have a few ideas but there's just so much to absorb and I would be really grateful for some clarity.
I'd like to be able to give something back but at the moment I'm all questions - one day I hope!
My plan for my 10ft by 7ft victorian terrace bathroom is as follows....
  • full pedestal basin, close coupled toilet, bath with shower over and valves etc built behind a pertition wall, victorian style radiator & one window to tile around.
  • 12mm 400mm x 400mm medium unfilled travertine floor tiles
  • 12mm 400mm x 600mm medium unfilled travetine wall tiles
  • Currently cermaic tiles on skimmed plasterboard which I plan to remove and replace with new plasterboard. I don't think there is a stud wall behind the plasterboard but just the old brickwork, I suspect it is bonded rather than screwed and plugged
  • I believe the floor is currently ply wood which I may replace with the same to keep cost to a miniumum
I would appreciate help from anyone with a few questions which are:
  1. Can I replace the plasterboard and using a dot & dab technique rather than plugging and screwing into the old brickwork?
  2. What adhesive should I use for a) the floor and b) the walls? Can I use the same stuff? Waterproof for all the room?
  3. Do I need to prime the plaster board? If so, with what?
  4. Should I seal before laying the tiles as well as after?
  5. What's a good colour grout for medium coloured travertine and leading from that question, what grout should I use?
  6. When grouting, can I spread the grout over the entire tile as you would with ceramic or do I need to be more precise when filling the gaps on travertine?
  7. What's a good tile spacer size for these size tiles?
  8. Best notch size for spreading adhesive on walls and floor?
  9. How big a gap should I leave between where the bottom wall tile meets the floor tile... and what about internal corners?
  10. I'm going to get a Rubi 180 for this job. What do I need for drilling though the tiles for radiator pipes and other fixtures and fittings such as toilet roll holder and towel rail?
  11. Do I need to use Silicon anywhere? If so, what would you recommend?
  12. Is anyone against using Lithofin sealants? If not, what specific product should I use to keep the stone looking as natural as possible?
  13. Presumably the process is... remove existing tiles and suite, temporary fit new sanitaryware, sort plumbing, remove new sanitaryware, tile walls (apart from bottom tile), tile floor, tile bottom wall tile, final for on new sanitaryware? Does anyone disagree?
I think that's it for now. Sorry to be so prescriptive but it helps me to try lay my thoughts out on paper (head's all over the shop at the minute).
Thank you very much
Chris
I dare not say out loud. We only have one bathroom so I suspect the good lady is going to be visitng M&S's loos for a while longer than currently promised😳
I'm hope to have most of the prep work done by 28th March. I have a week off work from 29th onwards which includes a Bank Holiday monday so 8 days at it (also bearing in mind I have a 16 week old little girl who doesn;t like me banging past 7pm at night'
.... don't say it!
Took a trip to Tile Giant at the weekend. Went in looking for Keraflex Maxi but they didn't have any so ended up walking out with Keraquick for the same price. Not sure if that was such a good decision given I'm new to tiling. I guess I'll be mixing lots of small quantities.
Anyway, the chap there recommended LTP Grimex to clean my travertine. I have a question about the order I should do things. My current plan is...
Lay travertine
Use Grimex
Seal with MN Stain Stop
Grout
Use Grimex
Sealwith MN Stain Stop
Does this sound ok or am I going to run into any problems?
Also, had the tiles delivered today. They arrived in a crate and had clearly been stored outside as the tiles are wet. I don't have a lot of room in the house so I'm spreading them out and drying them off. Presumably they need to be bone dry before laying?
Cheers
Chris
Chris,
Just to confirm, are you still intending to use unfilled travertine?
If it is unfilled, I would hesitate with the sealing prior to grouting as it will prevent the grout grabbing in the unfilled holes.
I would use your judgement with regards to the Grimex, too. If you work cleanly and remove excess adhesive from the grout joints as you go, and just keep washing down and working with clean water you may not need to worry about using the Grimex.
Follow the instructions carefully on the grout bag and clean it appropriately in two or three careful washes and you wont need to worry about the Grimex at that stage either.
One last tip, make sure that you let the travertine dry fully before applying the sealer, i.e. at least 24 hours but longer if you can.
Good luck and I'm looking forward to the pics :thumbsup:.
Daz
Hi Chris,
Looks like you are well and truely sorted for advice. I work for a stone tile company rather than being a tiler but if you wanted to have a chat about anything re the actual stone itself I'll gladly help. That goes for anyone with stone questions.
Cheers
Abbi
Thanks once again, Daz.
The travertine is honed and filled so I take it I should be ok sealing before grouting.
Thanks for the tip on drying the tiles fully before sealing - very useful. I mentioned that the tiles were really wet when delivered so I'm spreading them out around the house to dry them out. As they dry they are obviously changing colour and becoming lighter. The dying is also showing up all the dust from the stone. From other threads and what I've picked up so far I understand that I need to ensure all this has done before sealing and or grouting otherwise I could end up sealing in the dust leaving me with a 'film'. My question is - what's the best way to do this without soaking the tiles again and subsequently having to wait for them to dry. Can I just use a damp cloth over each one before I lay them or should I use the Grimex? Should I even bother doing this before laying them (as they'll get a little "dirty" when laying anyway)?
Abbi - thank you for your offer of help.
Hi Chris,
We would usually advise people to use a cloth dampened with warm water. You can use a washing up sponge as long as its white if you need something with a bit more umf to get rid of the dust. Just dont use anything coloured in case it stains the un-sealed tile. As long as the sponge/cloth isnt sopping wet and there is some heat in the room they are in each tile should dry out very quickly.
If you lean the tiles agains the wall face to face with a good few cm space between the two faces at floor point that give the air a chance to circulate and by the time you've done them all the first lot will be ready to give a light coat of sealant. The strong cleaners should only be necessary on slate and other tiles that have a riven surface as they are super dusty. Be careful not to use anything too abrasive or acidic as the travertine surface will be damaged.
Hope this helps.
Abbi 🙂
BTW, stone tiles are wet cut so often the dampness is just that they were stored tightly packed, straight from cutting and never had the chance to dry out. 🙂 Abbi
Hi Everyone,
I've spent the weekend removing all tiles, old plasterboard and old 6mm ply floor and have now pretty much replaced the plasterboard ready for plumbing and tiling etc.
Thinking ahead alittle now, I've bought a Vitrex Pro 750 for cutting the travertine but I have not, until now, given condsideration to edge cuts and polishing for my tiles around the windowsill for example. I've done some searches and it would seem that "edge" cuts are probably the best option for a diyer but I don't know much about what I need for the job and secondly how I polished the rought edges.
Can anyone offer any advice for the simplest solution without it costing the earth?
Cheers
Chris
Bathroom Tiling Advice
Unsolved
Beags,
kilty55,
Beags,
kilty55,
