is the art of cutting with the grinder
Still got my pin hammer, but can't find any Quarry tiles.
Still got mine in the shed as well...
When we were up at Albermarle barracks off the military road , we installed 1000.s lnr mtrs of quarry skirts.. scribe and pin hammer was the way around all those hangers and rooms... #soul destroying.
Interested to know your technique using an angle grinder.
I suppose hazarding a guess I'd lay tile on piece of wood and use another tile or something suitable as a straight edge and run blade along that. Would you just cut the glaze then snap tile like with a manual cutter?
For give my ignorance, I'm here to learn 😉
depends which cut you want to make, i.e: straight, curved, L. And what type of tile
for ceramic / Porc and straight cut then just manual cutter, same tile and L then dry score both lines, then diagonal cut to point of the L then back to your manual cut for snap. Same tile and curved cut then there are a few different methods depending on severity of curve, NEVER try to cut a curve in a tile with angle grinder if you feel your forcing or bending the blade, a series of light passes is what you need until all the way through however some curves need to sectioned in to smaller cuts by making a series of cuts at 90 degrees in to meet the line of your cut ( hope you follow) in any case, it's going to require a lot of practice, skill and a few scary moments to become good with the grinder... Just be carefully and wear safety gasses and don't remove guard. Very aggressive machines!!
No, seeing the blade flex like a piece of plastic whilst spinning at 11000 rpm certainly gets the heart beat racing. Don't make a habit of it or say bye bye to one of the ends of your thumbs
if I could design a safe angle grinder it would be pointless as the guard would encompass the whole blade, you would only hear it spinning lol
I don't have the guard on my makita grinder... 🙂 ... fully bespoke machine and easy to get in from any angle when shaping stone... the guard inhibits this.. it is my choice..
I don't have the guard on mine either Dave, like you, I cut from all angles, underneath etc, the guard doesn't allow that. I wear ppe and if anything should happen it's my own fault.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 2 1.2%
    Votes: 5 2.9%
