Richard Edwards
Pjc has seen it in the flesh and his advice is probably the most reliable - That said it looks to me like the all the floor and walls need to removed. The floor will need a proper pro prep job - hardibacker / Lux cementous board / Uncouple membrane on the timber and overlap the concrete by approx 500mm and the whole floor will need leveling. Then retiled and properly grouted. - It looks like those tiles are quartz or glass composite. The walls will need to be finished and made flat and vertical before re starting the tiling. - This is going to cost a pretty penny to put right [No actual costs please as open forum]
This is amongst the worst I have ever seen - and I seen some horrors as I do a lot of remedial works.
I wish you luck - even if its too late
