Kerakoll Fugalite Eco :)
How does it compare to the bisazza fil gel?
Hell of a lot easier to clean and apply. You dont need to use any white pads with Fugalite. Its better than all the epoxy grouts Ive worked with, even the hybrid by Ardex which I didnt like at all.
I was using it last week in the hot weather and it didnt seem to have any effect on it, it stayed the same consistancy through out application. I think the only time it could be a bit of a pain is using it on ceilings, as its quite loose.
I have only used the Transparent, I assume the colours will be just the same.
It can also be used as an adhesive.
Have you try to use the Heat Gun for see if can be easy to replace?
I had fuga wash in my clean up water but no soap. Tried it since but tbh didn't see much improvement. I tend to do my final residue clean up the next day using fila graffitti remover.
might be worth trying their Fuga-Shock Eco as thats stronger.
It's OK. Smells less than usual and nice and soft to use but i found the oily residue very difficult to get off polished porcelain. Easy to clean off mosaics and anything textured though.
If the polished porc is porous Fugalite should not have been used as it cant be used on anything porous.
Sharon - we used this just a few weeks ago on a mosaic hot tub and with the fuga wash ( which they insisted we use) was so easy to apply and remove . Light years ahead of epoxy groups.
just read the words on the can. to understand, that's light years ahead. ahah Made in italy
The tilers here, they all want keraroll epoxy, I have tried (colored) and I found it more coarse grained,
compared with Bisazza.
yes, the cleaning is very easy, I only used hot water. the seller told me that try to turn yellow with time. I tried it with a 20x120 wood type, quite rough. I also tried a type Mapei, very similar.
MTiler,
Simons70,
MTiler,
Simons70,
