Richard Edwards
Dear Groucho
I am saddened my your sorry tale. I am a big fan of Limestone and have layed it for clients and myself.
It's important to think clearly why this has happened.
The acid based cleaner has etched the limestone - ie dissolved some of the softer parts of each stone piece and hence the result.
Calcareous stones - Limestone, travertine etc are formed my calcium desposits from seashells and other marine organisims and compressed and hence are basically alkaline deposits. Using acid dissolves the material - hence why they used acid in grout cleaners - to dissolve the limestone used cement production.
To get back to the original surface finish you might have a look and a caustic soda wash - but try a really small area first and start well diluted, uping the strength as you experiement. Watch out Caustic, is exothermic and mix crystals slowly to cold clean water with wooden stick. ! Wear eye protection and gloves.
I think HG Impreg is OK - use the special thicker molecule version for limestone / travertine (White bottle) and thin the first coat with turps and apply with wide soft hand brush as it gets better penetration and wipe off straight away.
In sympathy
Richard
In sympathy
Richard
