Opinions On A Cracked Basin Please? (solved)
Interesting, I can see its merits for sealing to the tray for sure. How do you get on with corners of walls with it? Tank it then stick it on once dry? Does it stick like you know what
The instructions said to stick it on first and then tank over the top. It's very very sticky! I am even a bit concerned if I'm going to be able to peel the excess off the tray after tiling!
If its like the tanking tape I use its sticks like dooda to a blanket. Overlap it onto the bath or tray, tile over, and any excess just run a sharp stanley around and peel off. Any bits left I clean off with a wet wipe.
Tiling's finally finished!!!
Going to grout and Silicon over weekend and final fix Monday.
I really like the tiles.
Sizings are good but seriously bowed. Even 3/4 bond wouldn't work! No matter though as I was always going to stack them.
Found the difference in shade between light and dark to be a bit too extreme (made me think there was different batches) and in a couple of areas I've managed to put the darkest by the lightest and only noticed the next day. I can live with it but tiling at home, nice weather, then you start on the beers and these things happen!
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
