Plasplugs Contractor Plus or the smaller Pro Plus/DWW082 Compact Wet Tile Cutter
Just bear in mind the compact plus wont last long if you chuck grade 5 porcelain at it. Any repetative cuts on really hard tiles you want the master tiler for.
If your just cutting small bog standard ceramic wall tiles then the compact plus is brilliant.
gonna give the contractor back and get compact plus...i only do domestic stuff at the mo and it seems ideal for inside small kitchen and bathrooms...thanks guys...
hi m4ubs...keep the contractor and get the compact aswell then you have best of both worlds...
I've yet to buy my wet cutter was thinking of the contractor plus. I see you get 2 blades with it, a general one and a turbo blade. Which one do you use? are they both ok to use.
Turbo blade is great for ripping through stuff like slate. No good for porcelain/ceramic as it chips the glaze. General blade suitable for glazed.
sure its a master tiler? plasplugs sell them to retail outlets for more than that at theyre non offer prices.
got this wet cutter at topps cuts every thing🙂
I use a 4inch angle grinder with a diamond blade in from tradetile, do all my cut with this, it takes a bit of getting used to, also i have a sigma 900mm radial wet cut machine, tx50 and a tx900. Think i have rnough with this lot.
m4ubs,
m4ubs,
