Guest viewing limit reached
porcelin tiles
My Montolit cutter has an adjustable spitter. get this set correctly and it will cut cleanly without splintering the tile. Snapping the tile is done by stomping on the handle...yes, with my foot !!!! Is this just a little extreme or is this heavy footed technique the same for Rubi and Sigma?
Cmon you chatty lot... how do you cut yours?
sigmas are the best, FACT 🙂
Which Montolit are you using to compare your sigma with Scottish
tiler
Rubi rules!!! tiler 101 you must not be using the rubi correctly if you cant snap a porcelain clean with it ( tx ). Never used the sigma, but dont think id ever need to really.
Hi Brummie
Your cutter doesnt have the single point breaker system mate it has their new breaker. Really speaking the TX and sigma fit into the same catagory so you wouldnt see an advantage
tiler
Hi Len
You are using an older model of montolit. The raimondi which is identical to the montolit have a simple breaker with thickness adjustment and you push the scriber. The breaker requires just a tap with your hand. These cutters are developed and manufactured in Italy and are the muts nuts in quality and operation. Ruby changed lanes about 5 yrs ago because their single point wasnt working on porcelain, Sigma introduced the clik clak breaker into the uk but isnt really taking on. Companies are playing catchup to raimondi and monto who have a pedigree for porcelain.
Of course this is just an opinion 🙂
tiler
Im confised again 101,and i cant spell! I gather that their are two snapping systems with Rubi's cutters. Which one if either is better suited to Porcelain,and can you name the models?
Am not really happy with my Montolit 93P2. Cuts 930mm
The ruby tx range has a new breaker which seems to work well with porcelain and it pains me to say it. Personally I would get hold of a raimondi they are **** hot and wernt dreamed up over night like others
tiler
sorry 101. I overlooked your detailed history of the various cutters. Ok so its , your opinion but its the only opinion on offer so far, and gives me the impression that you know what your talking about. Am off to wander the 'net in search of this character Raimondo . thanks again
NO. No urgency thanks. Searched without success on the net by the way. why cant i find them?
Here you go Len : [DLMURL="http://www.raimondiutensili.it/index.php?lang=uk"]:: Raimondi Utensili - Home Page ::[/DLMURL] as I said come back to me
tiler
porcelin tiles
Alison,
len,
Alison,
len,
