Should rustic black slate calibrated look like this? Help?
That is a terrible installation done by someone who hasn't got a clue as to how to fix un-calibrated stone.
Created on iPhone.....
At the beggining of a natural stone/slate job I usually sort all the tiles into thickness piles. Start with the thickest tile and work down thicknesses, this way you can get a level floor. The thinner tiles can use a bit more adhesive but you should end up with a level floor.
Looks like the tiler has just thrown them down with a normal bed of adhesive.
unacceptable mate i am quite new to tiling and i know it should not be like that he has just laid them as they come out of the boxes he should of took them all out and graded them before laying
did the tiler put a self leveling compound over the floor, once they took the old tiles up?
you say you had no say in who the tiler was, did you get a mandate from the insurence where you had to chose the tiles from topps and use a topps recommend fitter, ive come across this in the past.
by the way the floors shocking!!!!
Had this trouble last year with these tiles from Topps...said Calibrated on the boxes, took them back they said it was a misprint on the boxes. The ones i got were rubbish, ranging from 3mm to 25mm.
thats a discrace. pic 4 must be 6-7 mm lip. no matter if he knew how to fix them or not he should of spotted it after a few tiles and took the time to re think the situation. if the tiles were that bad he should have spotted it and stoped before it ended up like this.
No, we were told to choose them we could choose from a couple of companies and Topps was one of the but the company who are doing all of the insurnace work had different trades coming in and one was their tiler so we had no choice over Tiler. I'm not blaming Topps in any way. The tiler laid something on the floor that meant the floor was perfectly smooth after the old tiles were picked up. We're not sure what to do now as we have registered a complaint with the insurance company as the contractors are blaming the tiles - they suggested we have something else when we chose these and said we were effectively told "we told you so" when we complained.
It's a 10mm lip. 5mm and upwards on quite a few. My 3yr old has tripped a couple of times. It's so frustrating as we thought we were nearly finished with the upheaval.
this is the problem when every tom dick and harry thinks tiling is easy, a tiler that is used to fitting natural stone would of made a better job, even if the tiles were bad quality, if they thought they were that bad, and unable to produce an exceptable standered then they should never of laid them, and i.m.o a 10mm lip is not exceptable..
ellington,
ifindoubtgrout,
ellington,
ifindoubtgrout,
