Discuss Straight edges in the Australia Tiling Forum area at TilersForums.com.
David Rowell
Hello everyone. I had another splash back job today so this morning i was scratting
around for a straight edge to fix to the wall. I ended up finding a bottom slider off a set
of sliding sliding wardrobes i removed the other week. It worked an absolute treat. It was 2.3m
long light and already pre drilled.
So my question is what is your preferred straight edge and how do you fix them to the wall? Because
ive seen people use levels on youtube but didnt see how they fixed it
cone
Battens with masonary nails or screws. Depends on what the wall is like and if its an old stone house, best to use rubis or the tile tracker because more times than enough, when you hammer in the nails your batten moves abit and screws the same. One thing thou, I always have timber battens with me rather than look about for other things for the job.
sawn timber about 50mm x 25mm , when I have to , which isn't too often these days doing house bashing .
However , doing a job for a m8 this week 24m² bathroom , so will ping the baton on all the way round using my laser and bobs ur uncle. Can be a bit twisted but is only a case of wedging the first course off the baton to my laser level and then its onwards and upwards.
Diggy
cone
Fair point I do have battons also been a chippy my van and garage is full of them lol. Just none of them were long enough to span most the wall like the track did.
Just had a look at the tile tracker thanks for that #cone are they sturdy?
Tile tracker is better than the rubis but still bit tricky in places but once you get hang of itll be better than messing about with nailing/screwing into old houses.
White Room
ive seen these and the rubi ones, how do you stop them tipping? And how many do you need so your battens don't sag?
Russ
Just pack them out to keep them level, my first set were only 200mm high but just recently got another set and there far longer.
I have some screed rules which won't bend but for using a old levels just use an old rubi (I have both, the Raimondi's ones are my prefered brand) one to sit in the centre of the batten.
Sean Kelly
1,068
Ruislip
Rubi battens (although I don't like them) and I use old levels as the straight ledge. I sometimes put blobs of Silicon to stick them to the wall. I also use slithers of tile to stop them sagging in the middle.
Reply to Straight edges in the Australia Tiling Forum area at TilersForums.com
    • Winner
    • Funny
This is how I got covered in Celotex dust in the image from Simons post. It wasn’t much fun...
5K
Waluigi
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
Hi, I am due to tile our Kitchen floor at the weekend, we went all out for the Black Star light...
11K
T14086
Hi Fellas. I've (nearly) finished tiling my en-suite walls now and want to start on the window...
19K
Straight edges
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
