Tile Levelling Kits
Question. Using Genesis and Lash as an example, I'm trying to figure out how many clips would be used per tile. I know if they are laid straight bond, its 4 per tile. 2 at the top and 2 at the side (4 per cross joint). But what about say a 900x450 laid with a staggered bond? Am I right in thinking its 6 per tile? 4 on the long edge and 2 on the short? 3 around each T joint? or is there a way of using less?
Confuzzled!
Yep. 🙂
It will depend on tiles but u can still get away with 4,
U don't always need two on short edge, quite often the one will do, 3 on long edge.
And if someone dared to do proper brickbond, 4 on the top edge and 1 down the side? Also, I guess for a thinner wood effect (150 or 200), the end one wouldn't be needed?
Tbh Paul it's a judgement call at the time, no real hard and fast rule.
Well, I spose it gets complicated it you're trying to inform a diy'er.
But in honesty, they're not for the non tiler, they can be very difficult and frustrating to use.
They'll probably break as many as they use!
And no levelling system is cheap like that.
new raimondi, (new. by the end of 2014 ...).
they do not break (said and repeated at least 5 times).
with 10 boxes 2000pz. broken at max 50pieces.
Tile Levelling Kits
oompedoomp,
Stef,
oompedoomp,
Stef,
