Tile Levelling Kits
Yip, these pink clips are just under 3mm & I still use spacers.
Just noticed I put the wrong photo up.
Those white clips are 2mm & I still use a 3mm spacer with them. 😀😉
I ordered clips & wedges from Italy, very similar to Raimondi but a lot cheaper.
When you say you level a floor with cement board & rapid set what do you mean?
Are you dry lining the floor with the cement boards?
What was the name of the system called? I used raimondi the other day and think they're very good but a bit pricey. Are the ones you found just as good but cheaper?
Tile Levelling Kits
oompedoomp,
Stef,
oompedoomp,
Stef,
