Tilemaster Tilemaster Grout
You guys who use tilemaster ,whats the grout like mainly just grey or white flexi ,appreciatte your appreciatte your input cheers
I find both grouts easy to use, only problem I find is when grouting rectified porcelains it dries fast on the face of the tile, but stays to wet in joints,
I spoke to technical dept & they say knock it up as stiff as possible. Easier said than done without a paddle.
The fl is rapid setting , that's what I use for porcs & find it ok, you get that issue with the fs but I just use it for ceramics.....
Use a bit of the flexmaster additive, helps bond to the porcelain and dries in 10 mins.
Better to use a resin or paint whisking paddle using a cordless drill on slow speed. You can pick up those whisks for £5 and everybody has a cordless drill
If he's a tiler and he hasn't got a paddle then he ain't going to get a separate little grout whisk before he gets an addy mixer! And if technical say mix it thick then thick it has to be.
Tilemaster Grout
Tilemaster
Unused Account 1,
Time's Ran Out,
Unused Account 1,
Time's Ran Out,
