Discuss Tiles falling off 12mm ply.... in the Canada Tile Advice area at TilersForums.com.
kilty55
1,113
edinburgh
interesting thread peeps...personally i use moist resis plasterboard on most jobs in wet areas and have done for a while now i tile them correctly and ensure baths trays are correctly fixed and the Silicon work is also high standard
i have been back to these jobs sometimes a few years after done to do other work in same house and on inspection zero issues as i have covered all bases
i have however ripped out loads of bathrooms some only a year old due to shower trays bouncing around...baths not fixed properly...stud walls not sturdy enough....Silicon work poor....wrong grout used...poor grouting these are the main causes i have found that cause failure on the boards yes they fail when wet so dont let them get wet!!!!!!!!!!!!!!!
i have yet to find a well fitted bathroom that the plasterboard substrate has failed on due to its own failures to be honest im sure they do exist somewhere but are they the common denominaitore...no imo they are not
fit the rest of the job correctly as well as your plasterboard and i do not see any issues
just my opinion
regardless of who the supplier of materials is do you think they will be man enough to admit liability without a fight /excuse if it goes wrong what a load of nonsense
widler
1,328
England
I actually have never said that PB is better than backer boards. I said,again, plasterboard has been used for years before backerboards, tanking ect ect blah de blah ect ect ect , and of coarse better solutions come out blah de blah ect ect ect , and yes when they get wet they are buggered ect ect ect . Also i would wager all tilers on her have tiled plasterboard shower areas in the 70s, 80s 90s, its how they did it, is it not;)
Ive been to hundreds upon hundreds of houses in the little time ive been a tradesman( not a proper tiler mind, only a mere plasterer :) ) and tiled many which have been fine, a lot more that aint.
Good little thread though,shame we aint in a room drinking beer and doing it, would be fun.
jonty1
I disagree, firstly because it's not pistols at dawn but because he can see a debate going on and make his own mind up. I don't think anybody has advised him to keep the ply, so he can either either go down the route of tanked PB, backer boards or one of the other offerings in this thread. I'd say there is enough info on pros and cons in the thread to see what sits right with him.
I didn't realise this thread had started such a big debate! It was 3 pages at the last time I looked in and then it reached 5!
All good stuff though and you can't beat a bit of debate to put different ideas into a thread to help people make informed decisions.
I'll post some photos of the shower when we built it as soon as I have a chance so you can see. It seems the ply has to go which is not really what I wanted to hear as it involves the most disruption and "homework" time for me... I was hoping I could tank it or go over it with thin wedi, but it looks like they are both a bad idea. I haven't taken the tiles off yet but I am guessing the ply should be fine because that shower has never been used after finding out that it leaked.
If I remove the ply, can I cut it flush with the top of the tray and start with backer board from that point. (The ply goes down to the floor on all three walls, back, left and right, (below and behind the side of the tray), and it is screwed into the sole plate....) This last 2 inches or so of ply will need the tray out to be removed and the tray is probably siliconed down to the floor and side of the ply etc etc.... so it could be a pig to get out now.... If I cut the ply at the top of the tray then I would have a joint right where I don't want it, right around the entire tray.... Seems like a bad idea to me.
So does the tray have to come out too then start again from the floor up if I redo it with backer?
I'm still interested in anyone's thoughts on any way of tanking or lining the ply if possible and if it is in very good nick because this is definitely the fastest and simplest route. But if it's a no go then so be it.
jonty1
Ok so it's been a while and I still haven't got round to sorting this shower out. I just took off the tiles today to reveal the ply backed walls as can be seen here: View attachment 56226 View attachment 56227
It seems the tiler has back buttered the tiles as the joints show no sign of adhesive and appear wet.... The ply is in good condition apart from the odd area of mould. The tiles came off like paper in my hands. I want to sort this mess and re-tile tomorrow and Friday if poss, so would like to ask if I can clean up the ply and wedi or similar board over the top or tank over the ply and tile or if I need to cut out the ply out and fit backer board or similar instead. If poss obviously I want to avoid taking out the ply so any ideas or help to do it this way would be great and that is really the solution I'm after... If not then of course I will rip the lot out and start again. Problem is I have limited time off to do this sort of work at home so need to fix it during time off work. Surely I can tank or wedi over 12mm ply??
jonty1
jonty1
Well I've made a start yesterday. ripped out all the ply, and then the tray wobbled..... blasted plumbers as well as the tiler now... I was cursing....... So I knew exactly what this would entail.... yep down to the kitchen, cut a nice hole in the ceiling to find the waste trap and disconnect it, then lift the tray out (dry set on chipboard.... and rocking like a good'un.. nice one), Then clean all the old Silicon off everything, board the shower walls, and then bed the tray down properly. So now I have basically re-fitted the lot, including repairing the new hole in the kitchen ceiling. Tiling it today
Here's a couple of photos after boarding:
Q
Qwerty
View attachment 56274 View attachment 56275 View attachment 56276
What have you done to tank the aquapanel boards & joints?
mike1979
I've read through this post and it's a bit of a funny one I'm bound to get sarcastic comments or the mick taken as every post I seem to make it feels a tad awkward perhaps I'm welsh and not in the "circle " but regards to all this shower business we all know wood is no good that's just nuts but all other trades should be educated in the art of wet rooms as plastered don't care I've gone to loads of jobs where they are boarded and plastered !! What I'm I supposed to do refuse it and sit at home plus the company I'm subbing for not their fault we are doing a housing site and they have wet rooms and it's for a big company and I'm sure they are plasterboard skimmed over but what are we suppose to do go to the site office and say that shower might leak they would tell me to get lost.
Sean SML Tiling
Im welsh too mike and I have had the odd sheep joke chucked at me lol if you work on site they just dont care about if its right or wrong they just want it tiled. I work on new build and nothing gets tanked or ever will. Private work I would tank. Its all ifs and buts. If it leaks then the plumber is responsible.
Reply to Tiles falling off 12mm ply.... in the Canada Tile Advice area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
