Tiling Bathroom Chipboard Floor Floor
Alexb
Hi, I was told that the bathroom chipboard floor has to be laid with plywood of at least 9 mm thick, before tiles are laid. In my mother's house some ago the bathroom chipwood floor was overlaid with 5mm plywood. Is it mandatory standard to use 9mm ply on bathroom chipwood floor? Thanks
I'd like to think my work will last until the customer gets bored of it not because they have to change it because it's coming up. The thing that gets me is that you keep advising fixing methods that no one has ever recommended! Why would you make up your own rules? If you can find me any written document anywhere where it recommends fixing to 6mm ply or indeed using the cow pat fixing method, I'll take it all back. Simply saying that you've always done it like that and never had a problem, really doesn't wash, for all you know, your customers tiling has failed and they don't want you back in their home to rectify it. I get a lot of recommendation and repeat work, so I'm fortunate enough to get to see work I've done several years ago and guess what, it's all ok and further more, it wasn't fitted with cow pats over ply wood.
Who mentioned cow pats on plywood? I certainly never did, as usually plywood floors are pretty level, so don't require that skill full way of doing it.
So if you were fixing say 600x300's half bond onto newly plastered walls, you'd lay to a spread would you and not build out?
You have bigger lips than Elvis lol.
And also, most of my work is repeat custom and word of mouth so I must be doing something right.
You can think / say what you like, I'm not too bothered.
My methods work for me, always have upto now and that's what matters.
I think the fact that you've been pulled up by several members regarding your fixing methods, should make you think a bit more about what you're doing. Anyone with an ounce of professionalism or pride in their work wouldn't even dream of fitting tiles in that fashion. Whether it works for you or not is irrelevant, it's wrong and isn't recommended by any manufacturers. Basically what you're saying is you know what's recommended but, you don't give a toss. Why, when there are so many proven methods and products out there, would you choose not to use them? As I said before, find me any literature that recommends fixing tiles to 6mm ply and I'll take it all back.
Well the short answer is "no". British standards recommends 15mm (with suitable adhesive, grout and priming system.
I used to fix myself onto 9mm ply using the more expensive higher spec 2 part adhesive systems and as far as I know they didn't fail.
Before that I used the two part directly onto the chipboard (adhesive makers used to say it was ok to do it this way) it wasn't a reliable method. I have seen many fails on 12mm and thinner ply's when the cheaper less flexible adhesives were used (at one time adhesive makers said 12mm was ok but they don't now - I did loads of floors this way and had no come backs).
I have also seen a 6mm ply floor that was being replaced even though a 2 part adhesive was used - the boards could be easily lifted leaving the screws in the sub-floor.
BUT the industry has moved on, there are now the already mentioned tile backer boards which add stability to the floor in a much thinner format than the plywood (eg 6mm compared to 15mm). They are not affected by water (although obviously the chipboard below will still be). They have been designed for this purpose and have been tested as being suitable for this purpose. They are readily available and cost effective so why use Ply?
Threads like this make me moan about the tile association again. I respect anyone's right to tackle a job the way they want to. Fixing cow pats to 6mm ply if they want, so long as they take responsibility. But those of us who want to do things 'properly' and by that I mean no offence. (If you take offence at us using the word 'properly' then you really need to go away and think why you're offended by it!) any way, I joined the tile association hoping that it would help to differentiate me and my methods from the 6mm ply groups out there. It didn't. Total waste of time and money. They have no interest in the likes of us on here.
Arguing on internet forums like this is pointless. A tradesman is only as good as his last job.
I had a call on Friday regarding a floor that has just been finished by a tiler........ Customer told me how good he was.... he overboarded the floor with ply and everything. A week later and three tiles have cracked. What would have caused this she asked. I went one to explain about substrate etc. She didn't want to hear anything i was saying. The long and short of this one is the original tiler has no idea that his floor has just failed after a week. She won't get him back to rectify it, even though i said she should.
If you do bad work you will probably never know it as customers won't call you back to rectify it they will just move on to the next person to rectify what you have done.
