daz1968
where is the best place to start tiling on a floor
i have marked the centre of room , but was considering starting from one of the right angles and working towards the wall , filling in that quarter and repeating the process on the other right angles . does this make senseI find the centres and work out all the cuts, once I know where the first line of full tiles will be closest to the wall I start there, put all the cuts in as I go and work to the door.
Make the floor out with a marker pen or use a guaging rod, try and make sure all cuts correspond to each other.
iiam a plasterer by trade thats why the questions , the floor is a one off for afreind. the roomis a small kitchen 18 x 12 which is bare the units will be fitted once tiled, the room is pretty square so measured to get right angle in the centre so now ihave four sections i have guaged the cuts and are ok becuase of units and the doorway is over half a tile. iwould like to be able to complete one quarter of the room including cuts then start on the opposite quater etc till i reach the door , does this sound okayi would look at the floor from the first angle i.e.doorway, if it would look better with full cuts to a certain area i would go with that so as the cut tiles are in a more hidden position, if the floor was a perfect square then maybe start in the middle and work out but always working to the doorway to make my escape........Alby
i am not sure what you mean. do i strike my lines then with my straight edge as a guide start running rows down the center line towards the door and across the the bisecting line towards each wall!No, do a couple of rows at a time, completing box sections is not advisable
