tiling floor
I'm telling Daz about how I learned, yes I was a beginner once too, albeit nearly 30 years ago:mad2:
Daz, if you decide to do that just double check the main wall is square with the door wall. If you do an L shaped dry run it will be obvious.
“Friends are as companions on a journey, who ought to aid each other to persevere in the road to a happier life.”Pythagoras
i have a builders square so i will be okay with the pythagoros bit, but why can i not once squared the room work from the centre out to the wall
If your tiles are plain and it's a straight forward set, working from a far wall will give you more working room and lessen the chance of tile movement/contact whilst your'e installing.
if you do it in grids ,or quarters Daz, all it takes is oone joint to be slightly out of sync and the following tile joints will either bird mouth or tighten up. If you go in straight full courses including cuts, you minimise the chances of this happening:thumbsup:
good advice Doug, similar to what I said, take the help offered daz, its all relevant to helping you. No one is going to say things that you want to hear mate.
We stick to the rules here matey.
:thumbsup:
if you do it in grids ,or quarters Daz, all it takes is oone joint to be slightly out of sync and the following tile joints will either bird mouth or tighten up. If you go in straight full courses including cuts, you minimise the chances of this happening:thumbsup:[/Qdo you leave spacers in between tiles or remove them, also i would love someone to email me a drawing of positioning tiles correctly for floor [email protected]]
