mikethetile
most of the deflection in a wood floor is in the floor joists, this shock absorbing bounce is deliberate and calculated, to tile over the bounce or deflection needs to be taken out or the job will fail
with fixing to battens onto a concrete base there is no joist bounce, if the chipboard flooring is laid brick bond pattern with glued joints it becomes as one and there is virtually no deflection, hence chippies insisting that chipboard flooring is stronger than ply,
chip board is chipped wood glued and compressed into a board, green cb uses a waterproof glue which will resist breaking down when wet
however the compressed surface of chipbard will not resist mechanicly pulling the tiles up. this job appears to have been a success due to lack of deflection in the floor and hence no cracked grout, but the tiles adherance is only as strong as the facing of the chipboard , which believe me is easily delaminated
