Topps bridge saw
R
robbo
Anyone own one of these or have any views on it? From Topps......
PROFESSIONAL 900W BRIDGE SAW
Powerful 900 watt (1.5HP) Induction motor
Overload protection to prevent motor damage
Motor trolley unit with ball bearing runners
Includes folding stand, mitre guide & parallel guide, folding and adjustable legs with wheels at rear, Detachable storage shelf
Large aluminium cutting table (92x46cm), large capacity water tray
200mm Diamond Cutting Wheel
Cuts tiles up to 600mm in length & 38mm thick
Cuts Granite, Porcelain, Ceramic, Quarry, Terracotta, Marble & Slate Tiles
Tilting blade for 0 - 45 degree mitre cuts
Decent cutter for the price Robbo, just be aware that it should be used outside, feedback from my Topps days reveals that it runs water over the sides....Gaz
Thanks for that Gaz, just looking at the mo as i've possibly got a big diametre slate job coming up and not sure if the cutter i've got will be man enough....
This is the one i have
Erbauer ERB180C Tile Cutter Chrome Top 230V
Tile Cutter with a convenient table size. Table is tiltable for various applications.
  • 720W
  • Blade Guard
  • Waterproof Switch
  • 180mm Diamond Blade
  • Cutting Depth at 90° 35mm
  • Chromium Coated Table
  • Overload Protection
I've got one of those Robbo - Good machine.
I find that for the size of the beast I now wish I had gone bigger as 600 tiles barely fit - infact they don't if the cut is raking.
I've got a job where the LF tiles need mitring so will be hanging on to it for that but then I am looking to upgrade.
I have one that I use on bigger jobs. It does spray a bit of water out but I'm going to re model the splash guard to improve that. As for the cutter it is large and heavy but the wheels make it easier. It has always cut true and I have had no problem in cutting any type of tile with it. ' It'sone to impress the Ladies with, " my thats a big cutter you have!!" With discount at Topps they should be £179 but if you know the manager then £169.
these small wet saws are under powered and struggle on some of the harder porcelain, save up and spend a about £700 and get a decent one there are loads of good wet saws on the market. i bought a rubi d300 16 years ago never had a problem with it other than replacing the wheels on the sliding tray i bought a 1500mm brigde saw 2 years ago for lagre format diagonal cutting both saws were expensive at the time but have paid for themselves many times over both machines have 2hp motors which cuts through 99%of tiles like a hot knife through butter good luck hope this post helps you
Topps bridge saw
Unsolved
robbo,
Daz,
robbo,
Daz,
