You can of course use an un-coupling membrane...first then put the ufh on that...
SUITABLE SUBSTRATES FOR SCHLÜTER-DITRA:
It must be verified that substrates which are to receive the Schlüter-DITRA matting are even, load bearing, clean, and compatible. Bond inhibiting surfaces must be removed. Any unevenness or height and slope differences in the substrate must be levelled prior to the application of Schlüter-DITRA.
Concrete
Concrete is subject to lengthy deformation processes due to shrinkage. Concrete and pre-stressed concrete may build up tension because of deflection. Schlüter-DITRA absorbs inherent stresses between the concrete and tile covering so that the tile can be installed as soon as the concrete is hard enough to be walked upon.
Mortar screeds
According to the applicable standards, mortar screeds must cure a minimum of 28 days prior to the installation of tile, and their residual moisture content must be below 2% (percentage by volume). In particular, floating screeds and heated screeds tend to change shape or develop cracks after installation, e.g. due to load stresses or temperature changes. With Schlüter-DITRA, tiles can be installed as soon as the screed can be walked upon.
Schlüter-DITRA is also recommended for uncoupling of radiant heated floors consisting of thin electric heating mats. Schlüter-DITRA may be installed either above or below the heating mat. However, the uncoupling function is more effective if Schlüter-DITRA is installed above the heating mat.
Schlüter-DITRA - Schlüter-Systems
hi matt sorry you are hearing what you wanted to hear but these lads know their stuff.
No one has mentioned insulation boards yet. Ufh heating mats straight onto a concrete floor end up being too expensive to run!!
had a customer who wanted it doing immediatley, told her to wait until dry, (despite inconvenience to her) fitted insulation boards etc. She was delighted and has now forgotten about the 'waiting time' Do it right Matt and your wife will appreciate it in the long run even though you might get ear ache this week end.
Do these boards negate the necessity of plying a wooden floor? I hope so or youll end up touching the ceiling.
underfloor heating mat in self levelling compound
Matt123,
Dan,
Matt123,
Dan,
