*UPDATED* Wet Room Project Build Thread!
Hi guys!
Next up we have the floor! In the last update i go the linear drain in it's position. So next up was building the floor falls. I didn't want a tray because i preferred to make it. 🙂
So, the floor with Linear drain
So, time to remove the Anhydrite screed lattice.
Killer angle grinder!
And removed:
Next up was time to make the falls, 20mm per meter for the first meter to the drain then 10mm per meter for the rest of the floor.
Jig'ing and welding the former:
Wall Fixing
Former welded and in place
Side rails done
Rear Rail
Now i had a form in place to screed to i needed to primer the floor
Next up was the screed
First up i used Mapei floor adhisive to bond the screed to the floor/primer then a sharp sand 3/1 Mix with SBR.
Drain Masked off first of course
Here you can see the adhisive before the screed was compacted ontop
And done
Lovely that Adam..only thing I would have done different is to set the drain around 100mm away from that back wall so it could have had floor tiles enveloped all the way around the drain, sure it'll look fab, great prep work
Any updates on this project?
Would love to see some more pics!
Hi guys a bit of an overdue update!
So when we left off we had a tanked wet room.
Next up the tiling
So first i put out the batten and set out
Also brought a new toy!
Then up and away with the tiling!
Got to the window corners and the bit i was dreading, the miters...
first wall done, i didn't want to grout the external mitre so i filled them all
before and after
Next moved onto the floor and the other 2 wall's
labeled all the cuts for the floor
Next up me and my other half did the grouting...
Lovely job huh?! We used Epoxy grout, BAL Easypoxy AG Black, mostly due to wanting to make it as water tight as possible...
Using a set of digital scales to mix up exact amounts and using empty mastic tubes to apply the grout with
Then cleaning down the grout
My beautiful asistant
And done, this shows the miters after filling and cleaning
Onto the end wall
And the floor.. the dark patches are just water
More to come!
Tanking and Wetrooms
Adam18Spring,
Lou,
Adam18Spring,
Lou,
