dot and dab
If your method works for you and you're achieving solid bed without exceeding adhesive depth limits then good for you mate.
The bathroom you've posted looks like a very nice job but as for people on here being 'gobsmacked', i think not. Also, compared to some on here, 13 years tiling is not a long time.
I do the all the plumbing, joinery and plastering, not just the tiling and my old man's been in the game for 40+ years and is a highly mutiskilled builder. 13 years is plenty long enough but to be honest, it doesn't matter how long someone has been tiling, I know lads that have been tiling for 30 years and they're *****. As for people being, "gobsmacked" I was referring to one person in particular as apparently I was living in "cuckoo land" using this method. It would be interesting to see some of the work from the lads on here...see if some of them can they're put their money where their mouth is...
so you do all the joinery and plastering and still dot and dab...
I'm gobsmacked now pal!
That's what I was thinking...lol
You reel off a list of things you do yet you can't prep a wall or floor for tiling using a notched trowel....lol
Steve, you don't need to come on here all billy big balls, there are a lot of highly skilled and knowledgeable tilers on here, most of which I would think your not impressing
Couldn't really give a damn what anyone thinks of me on here and I've certainly not come here to impress, I've come on here simply to defend the validity of the way I tile. Some of you have been pretty nice and have some common sense, while others including yourself "Localtiler," have had a rather ignorant attitude! I've just flicked through a few photos of your work and it seems pretty neat at a glance. Look a bit closer and well, your wetrooms don't look up to much mate, one especially. And what's with recess? Can't you build it so you can get a full mosaic instead a tiny slither of a cut! Both these photos look a mess...and you're...ripping into me lol!
It'll look great then when there's water gathering in them voids!
I just tile I don't build voids and stud walls out.
You are supposed to Silicon to the drain, not grout. And the moisture you see around the drain is soapy water. Not that I should have to explain!
I can see more chips than my local chip shop in them elvelope cuts of yours.
It all comes down to you arguing that dot and dabbing is a perfectly fine method, when it's not. No need to get your knickers in a twist about it
dot and dab
diamondtiles,
Qwerty,
diamondtiles,
Qwerty,
