Suspended Timber Floor Tile Prep
All it means is that it limits where I can put joists on that section of the sleeper as the pipes are in the way, but at 12" OC its fine.
It does have an impact if you are overboarding the ply and need to build up the height of joining floors. For example, a Foam tile backer board would be unsuitable and instead a cement board like Hardiebacker would be OK on top of wet UFH
Ofc, its a problem for the other room. Thats not being tiled until the extension is built. Either way the ply will need another layer of something so I'll end up with a height difference. Can't lower this floor without rebuilding the sleepers.
Dense concrete blocks would work, you could place them under every second beam from the middle beam on the picture but you would have to put a piece of slate under the block or DPM to stop damp, may also cheaper & quicker
Eventually yes. I mentioned it in the OP these rooms will be joined so there will be a substrate difference and will need to be factored in. Thankfully the tiles will run with the join so at most its one tile that will straddle the two floors although I suppose you could just end of a full tile at the edges.
Or take ply up and put a thicker cement / structural board down. Double up joists and maybe even block and you should be sound as a pound
Deyna,
Just Rizzle,
Deyna,
Just Rizzle,
