Suspended Timber Floor Tile Prep
You can fix mechanical expansion joint to bridge where the 2 floors meet,& by cutting up to the joint continue it with the off cut & it still gives the impression that the floor runs through
Thanks guys, this stuff is good.
I've got spare timber, so I will go ahead and double up the spans showing deflection and re-test. I think this will solve any lingering deflection problems and shouldnt take a great deal of my time.
I'll look into Blanke Permat for this subfloor. The extra expense might be worth it (12m2), but Ditra would be more suitable for the adjacent room with screen/WUFH and more cost effective. Both add the same height so would work.
I live in Warwick if you would like to pm me. I can come have a look.
Cheers buddy, I'll be working on it this weekend so will report back after bolting some more 4x2's together. A second opinion would be much welcomed.
I should have gone gone 6x2 really and just cut back at the ends. Wouldn't have got anything bigger than that in though.
I've given it a bit more testing, and I've come to the conclusion that bolting more timber together will not reduce vertical movement to an acceptable level to be considered for tiling. However given the sleepers are 2 courses, I'm going to basically add another 2 walls mid span either side so the max clear span is 1m. I've got aload of spare blue engineering bricks here from the previous owners. A quick test of deflection over that span with some offcuts shows it will not move.
I agree. The thing with bolting them together is that you aren’t increasing the x4 part. They do need support underneath. You are doing the right thing.
Ye, the strenght comes from the depth not the width. I can leave the existing frame "as is" then (the extra support for board joins isnt a bad thing plus it'll still be where foot traffic is).
Realistically its about 50 bricks and I'll just have to make do with workaround around the existing frame. I will feel a helluva lot more comfortable with it then!
Ye for sure! I'll do the first two and consider rebuilding the others if thats the case to take up some of the slack underneath (upto 20mm shims in places). Feels like an extra weekend on it will be worth it in the long run.
Deyna,
Just Rizzle,
Deyna,
Just Rizzle,
