cornish_crofter
Shower area nearly done. I didn't mix enough adhesive to finish it 🙁. As it's BAL mosaic (expensive) I'll be preparing some other areas so I can move onto those after I finish, to keep the waste down.
Neale's idea of interlocking the panels works a treat.
The corner trim is from CTD at £3.95 plus vat a length, in Silver (Aluminium)
Hey Hugo, what is that what your tools are resting on? And that window sill on the left, will you tile that, too or leave it?
Like the trim. As I'll be using Bal mosaic very soon, too, and you didn't have enough, how much would you now say to estimate for?
And yes, Hugo, finished pictures will be great! :thumbsup:
Gisela
The tools are resting on 2 toolboxes.
The window sill is UPVC, so I'll leave it be. The window is a tilt and turn so there is absolutely no room for tiles. The window just clears the bath, I had to lower the bath to achieve this so the trap needed a clerance hole in the floorboard.
The BAL mosaic - I still have a third of a bag or so, the reason the tiles weren't finished on the shower area is that I didn't have enough mixed up at the time. BAL Mosaic is lovely stuff, though CTD are expensive on it even with the 30% discount. I got them to match Topps price of £24.46. I could have probably got it cheaper if I shopped around, but I will need 2 bags max.
I reckon I'll get about 70 or 80 square feet out of the bag. I may even have enough to finish the job.
These were my first ever mosaics. What I found is what you probably come up against all the time is that you don't need a thick bed at all. In fact a thin bed is best as it saves having to clean all the adhesive out of the grout lines.
cornish, out of intrest how do you go about putting a bath in with tiling around? is the frame just buil round the bath or is it actually supporting the bath??? Looks nice work by the way!
Tip for the driver.................if you use a mosaic tile and grout powdered adhesive you have no need to worry about the squeeze through messing you about you just wipe it off with a damp sponge. :thumbsup:
Ah, that would be telling 😉
This is the first time I've done anything like this, so I had to think.
The whole suite excluding the shower is actually salvaged out of another house, where the chap was wanting it all changed. I was missing at least one leg for the bath so I had to make sure it was adequately supported all round. IIRC there was at least one leg to support an end under the rim, but I didn't have this.
The bath was fitted then I tiled around it. The bath was fitted high enough to just clear the tiles, meaning that I didn't have to cut each tile that met the bath, I could just slide it underneath, so only part of the tile was visible.
To properly support the bath I built the basic framework then postioned and levelled the bath, and then used a 22 inch saw (blunt edge in contact with the bath) at 45° at each 'corner' to mark where I needed the 45° corner supports to go.
I then completed the framework managing to build in as much support for the bath around its perimiter as possible, fitted and cut the aquapanel to allow for the bath, then trial fitted the bath to eliminate interference.
Once I was happy with the position of the bath, I screwed the feet down, connected it up, checked for leaks etc, supported it in the middle, then foamed around the perimiter where I could. Because I managed to get a few inches overlap on the corners I could get good contact area and the bath is solid. I used the gun grade window fixing foam.
As said earlier I just tiled around the bath, and slid partly exposed tiles underneath the rim rather than cut them.
I was extremely grateful for the suite. It's an Ideal Standard Sottini Reprise, current design, I priced it up recently, would have set me back nearly £3k! Those taps are worth over £400.
The bath originally had a profiled bath panel, but on closer inspection it was quite badly damaged, so we binned it. We prefer the 'tissue box' it sits in, and we didn't have to find £200 to replace the bath panel!
Thanks Tony, Can you get different coloured misaic tile and grouts?
Hi mate,
a better quality image would show it off more, looking good.
Just a pointer, not sure how most people on this site fix their mosaics ?
However, it looks as if you have started at the bottom and worked upwards ? ( looking at un-finished wall )
If so it is generally easier with mosaics to start at the top and work down, the tiles fall down into position a lot easier this way :yes:
