strummerman
Did check and sign the work off when it was completed the fitter should av asked you to do this
We have recently had a bathroom installed by b&q, the wall tiles we chose were travetine 480mm x 330mm. i have several issues, of which the project manager is coming to inspect.
I need to be armed with information on accepatble levels of lippage and quality of tiling. I will post as much information as i can .
1. There are many areas of the tiling that has in excess of 2mm lippage, this has been measured against a 2p piece.
2. the tiles were cut with a circular saw, so many of the cuts have very rough edges and are not straight.
3. the window return is 10mm different in width from top to bottom, and i have used a spirit level to confirm this, needless to say, the blind that used to be in the window, now doesnt fit. it is an exact fit at the bottom, but now wont fit at the top.
My question is where do I stand in asking for these problems to be rectified, i have put poly coving up over the tiles at the ceiling and this shows many of the lippage problems too.
