Discuss Customer has changed her mind!!! in the British & UK Tiling Forum area at TilersForums.com.
pro-handyman
Hi all, Nearly completed a bathroom job floor-to-ceiling brick-bond 450x300 ceramics just the final cuts that butt up to the ceiling to left before grouting and sealing. It's a plain tile all over except for one row of patterned all around at about chest height. The problem is my customer has just decided she does not like the paterned row and has asked if they can be removed and changed!!!!
Can these be removed without jeopardising the strength/bond of the adhesive on the surrounding tiles? How can I gaurantee this?... Can I gaurantee this?
Is it a wise thing to do at this stage of the job?
Any advice please?
Thanks in advance.
mikethetile
Yes they are the same size which is one good thing. I'm just concerned that if they don't come off to easy and I need to go at them with a bit of force that it might cause damage to the bond/adhesion of surrounding tiles. The adhesive is tubbed bal green star.
shame you didnt ask about addy before starting the job
you wont have too many problems getting the addy off
CJ CERAMICS
if the are the same size as the field tile as mike has said then yes in theory you can remove them and replace with the smooth ones....but obviosly(dont think i spelt that right) you will have to be careful as to not to damage the substrate. if they have not been on too long removing them should not be too hard. just try to remove as much of the tile in one go from the centre of the tile so as not to chip tiles above and below. depending on how they come of (how much adhesive is left on the wall) i tend to remove most of it with a harris long handled scraper and sand the last flat using my bosch pmf multi tool.
hope this helps
chris
Reply to Customer has changed her mind!!! in the British & UK Tiling Forum area at TilersForums.com
In case you missed it change to the rules came in on 13th June 2014 - completely replacing the...
11K
Rizzle from the Portizzle
Hi guys, Ok so I have come to a forum to discuss this. Last 3 jobs I have done on full bathroom...
2 3 4 5 6 7 8 9
15K
went to start a floor today, when i got there the tiles were 400x400 polished porcelain from...
J.R Tiling
L
Hello all, My in-laws are currently having their bathroom refitted (first floor) and having...
5K
swanman
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
