Discuss Fibre slc thickness on wet ufh in the Canada Tile Advice area at TilersForums.com.
Midlandceramics
Looks like the video recommends cement board like I posted earlier.
thog looking at th above picture. Self levelling along with a good primer will cut the depth down by 20mm
I'd take no notice of there instalation methods mate !! They haven't got a clue . I was using the video to show the product !! I've spoke to there tech 3 times and there rep and all don't know what there on about !
I
Ian
This is spot on thanks look forward to the pics !! Finally I found someone with the same app from sub floor to trav !! Just out of intreast is the ufh the jg speed fit overlay system !! If not it looks very similar !! Thanks again bri ....regards . Jay - midland premier tiling
the system is Wunda Floor Heating
Midlandceramics
I'll get some more pics in a couple of weeks when I'm back there, there is a hot tub on the floor now! The SLC is weber floor flex, so yes, a fibre based one.
Would you mind e-mailing them to me ! [email protected] you have been a great help and gone a long way in easing my mind a little ! Regards j
Midlandceramics
No probs ! this is the way I was going to do it after ignoring there spec ! So yeh was just after the mm of slc but 5-10 mm looks ok !! Relief to find someone who has laid trav on this system ! And on this way ! Wonda floor are far more informative and have got there spec bang on !! Speed fit needs to sort there stall out !!
I
Ian
I had a lengthy chat with one of their tech team before I started the job,they are very clued up on the products that need to be used and, to be fair, the floor is rock solid as a result of using the recommended products. They knew all about ditra and S1/S2 adhesives so, had obviously tried and tested their product.
Stef
couldn't he just slc over it and while it is setting fix cement boards down over the ufh being careful not to hit the wires? just an idea like but doubt it will be a good one lol...... coats on doors open lol
Ash, cement boards must be glued & screwed to the substrate,
How will he achieve this with ufh?
Mr Tiler
moment of madness mate lol. was thinking with the slc down fixing the boards down through the insulation to the substrate would provide a suitable tiling surface... but thinking about it if the slc has nothing to cling to it is not very effective at all is it.
Mr Tiler
Ditra then travertine
Annoyingly, I don't have a pic of the finished floor! I was there again today and the floor is in perfect condition still, it's only been down a couple of months but, good signs.
what is that perimeter in the room by the levels bri? and did you have to slc the corners again on top of the ditra?
Mr Tiler
It's a drain, there is a hot tub sat on there now. You can see the waste pipe for it sticking out of the floor.
did you install the drain mate? its not there before the ufh went down was it? cant see properly tho and whats the addy in the corners was it levled again once ditra went down in those corners?
Reply to Fibre slc thickness on wet ufh in the Canada Tile Advice area at TilersForums.com
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
Hi, We currently have travertine floor tiles with wet UFH underneath. Some of the tiles have...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
